Posting this for a friend.... I know NOTHING about auto trannies. Thought someone here might be able to help:
When I got this car (93 Z28 with 148K miles) the transmission was pretty toasted. Wide open throttle shifts were like throwing the car in to neutral.
I knew a guy parting out a thirdgen and it had a built ($1800) 700R4
in it that I picked up dirt cheap. This 93 had a 4L60 in it, which I
always thought was identical to a 700R4, but they aren't. The 4L60
has a 5 pin connector, and I noticed it had what appears to be
electric governors in it. The 700R4 has a 4 pin connector and does
not have the electric governors.
At first we just eliminated the other pin and plugged it in to the
700. The converter would lock/unlock constantly, not good. So then I
was driving the car with the tranny unplugged, basically no converter
lock up control, and that's when all these problems started. I did
get the TCI kit to control the converter lock up in 4th gear and
unlock it when you hit the brake (kit made for non-ecm cars) but I
haven't installed it yet.
I did install a new (no name brand, Allstar) 12" lock up converter
(around 2800 stall) when I did the trans. swap.
Any ideas? Need to change something in the ECM?
