does anyone out there offer a hi performance PCM for the 3.8 v6?...and will that disable the second gear start feature in the automatic models?
3.8 PCM
Here is a link to the JET Performance parts website with all the Camaro chips listed.
http://www.jetchip.com/products.asp?...&model=432#432
I've never personally used a JET chip but I've heard good things about them. You might want to find someone on the forum that is running with a JET chip on their car to get a better opinion.
By the way the second gear start should be off unless you flip the switch to on; the switch is located by the fog light switch above your radio controls. (If I'm not mistaken even if you turn the car off with SGS on SGS will be off when you turn the car on again). The second gear start should not be used unless your driving in rain, snow or a place where you have low traction. I'm assuming your not talking about the skip shift either since you said its an auto.Speed kills... Drive a Ford and live forever!
