Has anyone ever had a coolant sensor fail on them? I changed the water pump not to long ago and flushed the coolant, replacing it with new coolant and checking the system. About 4 months later it sometimes reads that the coolant is low. I've bled the air out and checked it numerous times. I should check Shoeboxes website for a part #
Low coolant sensor
Low coolant sensor
Tags: None
Did you try cleaning it before you replaced it?Fred
I need one too!
Let me know...1997 Trans Am WS6 Black M6
370 RWHP / 352 TQ
CC306 & Comp behives, LT1 Extreme Duty timing set, 1.6 RR's, CSR Elec Water Pump, Pacesetter LT's & ORY, GMMG w/ Ovals, K&N, Air Foil, TB Bypass, !AIR, !EGR, !CAGS, 160 deg thermo, LT4 KM, PCM tuning by Total-ReCal, March Pullies, Pro 5.0, 4.11 gears, LS1 alum DS, BMR strut tower brace, UMI SFC's, LCA's w/relo brackets & panhard
Originally posted by InjuneerDid you try cleaning it before you replaced it?
Good idea, I'll try that first and if it appears to be clean but failing to work,I'll look into the AC delco replacement. Thanks1996 Z-28 6 speed, Airfoil, K&N FIPK, Flowmaster muffler, Motive 3.73 gears, BBK shorty headers, cut-out, LS1 Driveshaft, no power options (Rare), Prothane tranny mount, MSD 8.5mm wires, Accel U-Groove Plugs, Chrome hurst short throw, TB Bypass, ES Torque arm mount, BMR subframe connectors (weld-in), Lt4 Knock Module, Descreened MAF, '02 SS wheels, Pioneer HU, MTX & JL amps, 2 12" JBL's, T-Top Conversion!
