which is better? The richmond is more $$, but I thought I heard before that motive was quieter and just as good. Or was it the other way around?
richmond or motive?
richmond or motive?
Tags: None
I tried richmond 4.10 gears, they were extremely loud, no matter what setup was tried.I couldnt take it anymore so i went with a GM 3.73 and much better.
95 trans am, golen engine 383 ,140k,6spd, procharger 12psi supercharger,racetronix fuel pump, 58mm BBK throttlebody,hooker long tubes,crane HI6-DSR ignition box,crane ps-92 ignition coil ,true duals, 60lb injectors,3.73 GM gears,csr electric water pump,edelbrock strut tower brace,descreened maf,ls1 aluminum drive shaft,centerforce clutch,accel extreme heat wires,lt4 knock sensor,autolite 104s ,hurst short throw shifter,8-01-05- 02 frt end and taillights,ws6 rims,shiny black paint job!!.
Thanks a ton guys, I appreciate the input.
Motive's all the way. Just dropped 4.11's in my ride, and I absolutely love em.
NO whine at all!
1997 Trans Am WS6 Black M6
370 RWHP / 352 TQ
CC306 & Comp behives, LT1 Extreme Duty timing set, 1.6 RR's, CSR Elec Water Pump, Pacesetter LT's & ORY, GMMG w/ Ovals, K&N, Air Foil, TB Bypass, !AIR, !EGR, !CAGS, 160 deg thermo, LT4 KM, PCM tuning by Total-ReCal, March Pullies, Pro 5.0, 4.11 gears, LS1 alum DS, BMR strut tower brace, UMI SFC's, LCA's w/relo brackets & panhard
