I am going to be sending my motor out to be rebuilt soon and am thinking about the things that I want to do with it while it is out of the car and what are some things I can do as far as removal of some of the smog equipment.
I will be removing the AC (hasn't worked in a while anyway) the AIR system and the EGR system. The EGR has already been programmed out of the CPU due to the fact that it did not work. I will have the AIR system programmed out too. I understand that these systems don't really hurt perfromance too much but I want to clean up the engine compartment. Actually due to the location of the AIR system I nearly burned my car to the ground when a clip holding my fuel lines broke and the lines ended up laying on the AIR tube.
Anyway, what can I relocate/move that will make things easier. And are there any other free mods like the throttle body bypass that I should consider? I will be using a Holley 58mm throttle body and either SLP or Rk Sport headers. I WILL be keeping the CAT in place.
Ideas?
Ideas?
