1. When ever i get on the car from maybe an easy start, like say a normal start and drive it to like 2000 in first and then gun it to 4500 and then shift to second and hit about 42mph, my airbag light turns on for about 4 seconds then goes off. it does it at other rpm ranges and other gears too. What does that mean?
2. Engine definitely has some vibration that isn't normal. What is a good program for my laptop to monitor something like the knock on the engine and see if the car is being retarded down? Feels a little sluggish. I can't seem to find out what the vibration is. Took it to a mechanic and he didn't know either. I press in the clutch and the engine vibrates still. I engage the clutch and the car shakes. Gets real bad at higher RPMs and higher MPH (~80MPH and above -- Drag Strip at 101 was really noticeable and i thought the car was going to fall apart)
3. Last question. Since I have excessive vibration, my header bolts always come loose and I always have a header leak. What can i do to prevent that? I tightened them like last month and almost all of them are loose to the touch.
Any suggests?
Any suggests?
