What exactly does a strut tower brace do? I pretty much know what the others do, but what is that and what is its purpose (other than improved handling obviously)?
1983 Firebird with all original parts (with a fresh coat of paint on top)
Someone will post a better explanation than mine, but a strut tower brace basically just ties the front end of the car together. I actually just put an STB on my 3rd gen and the best way I can describe it is that it feels much "tighter" in the front end, especially in turns.
Anyway, since you have a 3rd gen, the first thing I would suggest is subframe connectors. They sell bolt-in and weld-in connectors, and I would suggest either buy weld-in ones and get them welded in, or buy bolt-ins, bolt them in yourself, and then later on get them welded in. I chose the latter, but it's just about personal preference. SFCs cost around $200.
After that (or before, again it's about preference), get a steering brace, usually called a Wonderbar. It just bolts in on the front of the frame rails, right on top of the sway bar bushings. It helps prevent flexing and possibly cracking the area around the steering gearbox (common problem on 3rd gens with larger wheels and tires). Some people feel a difference with a Wonderbar, some people don't. Either way, it's usually needed. Wonderbars cost around $50.
Once you get these 2 things done, then I would start looking at upgrading the actual suspension. Bigger sway bars, tubular LCAs and panhard bar, lowering springs, better shocks and struts, polyurethane bushings, etc.
Thanks a lot. Now my next question, would getting a bigger rear sway bar increase the overstear in my car and wouldn't that result in less handling? Or am I completely wrong on this one?
I believe you are right, but I'm definitely no expert.
Something I forgot to mention earlier, is that you can get some pretty good sway bars off of a stock 3rd gen, if you look hard enough. 86-92 Firebirds with the WS6 suspension and some 89-92 Camaros came stock with 36mm hollow front/24mm solid rear sway bars, if you don't want to fork out the $ for aftermarket ones. They should be pretty easy to find and are pretty cheap at junkyards. Just clean them up, paint them, get new bushings and endlinks, and bolt them in. Now you've got some great, matched sway bars. I've been meaning to do this myself for a while now.
Engine: 305 TBI (L03)
Trans: TH700R4
Mods: Some
Thanks for the advice. I need to head to a junkyard for some hinges for the back hatch anyway, so I'll take a look around for those sway bars. Also, I meant to write "oversteer" but, oh well, no one's perfect.
While you are at the junkyard, look to see if any of the 3rd gens have a shock tower brace installed. You would be suprised at how many are junked with some mods still on board. Look for any mod for that matter.
