My friend has a little problem,wonder if you can help please!!
trying to get the stock pcm to run trany while running a Holley Pro DFI
I don't know if any one has done this but I have installed a Holley DFI and I still need the stock pcm to run the 4L60E. I think it can be done if I supply the pcm with the needed information. I think it will only need the RPM and MPH input to be able to shift the trany and it did before going to the dfi.
My question is where does the stock pcm pick up the rpm signal? Is it from the opti ? What pin on the pcm connection do I need to supply the signal to.
