Right in front of the exhaust cross over pipe.
BTW If I remember right lookin gin the owners manual it states that the low oil light only comes on right at startup to check the light, then the oil is low and only for 20 seconds if the oil is low. So if I read that right it will only show 20 seconds after you run out of oil! Hope I'm wrong. I'll read it again tonight but that is what I got out of it.
Oh and another thing. You can use a big wrench and pull the sensor out. Its a good idea to clean it once in a while to get and junk and metal shavings that might acumilate on it and prevent the sensor from making a contact when you have low oil.
OK here it is stright from the manual "Notice: The oil level monitoring system only chekcs the oil level when yu are starting your engine. It does not keep monitoring the level once your engine is running. Also, the oil level check only works when the engine has been turned off long enough for the oil to drain back into the oil pan."
So it looks pretty useless if you are driving along and you loose oil all of a sudden. I wish there was some way to keep it on all the time.
