My fuel pressure is set to 50psi at the AFPR, when I turn the key to the ON position, I hear the fuel pump prime the system my pressure goes up to about 40psi and immediately back down to 0psi. I swapped out the injectors with 44lb/hr Accel's and after doing so, my pressure loss stopped (the injectors leaked down).
Now all of a sudden I have NO pressure unless I start the car, then it stays right at 50psi as set...when I turn the car off...back to 0psi.
I've checked the system and I have NO fuel leaks!
I do have a new Aeromotive AFPR, I'm just wondering if these are the symptoms of a ruptered diaphram? Can anyone confirm? Other possible problems?
TIA
KnightFire
TIA
KnightFire
I did it the ghetto way, I cut a hole in the floor of the hatch. I haven't welded it back together yet...thats probably a good thing right about now.
