How much faster is a 2001 + Trans Am over a 1999, or 2000 Trans Am. Probably going to buy 1 by this time next year. (If I wait a whole year might look into a 2001 since they will be cheaper then.) I will make sure I get 1 with the 3.23 gears this time. (Whats the code # for these gears, and is it in the glove compartment box?) Anything else I should look for? Will be automatic again.
Compare LS1 Trans Ams
The 01s and 02s have the LS6 intake. This is good for more than 5 HP and if you plan to do any mods on a 98-00 you will end up tracking down a LS6 intake. The performance is probably not measurably different -0 there is probably more variance from car to car (like an 00 vs 00_) than 00 vs 01. There were other improvements that hit in 01 too - check out LS1tech -0 there are a couple of threads that illustrate all of the differences.Silver 02 WS-6, 6 speed, Corsa cat-back, SLP lid, K&N filter, BMR STB, !CAGs, Lou's short stick, MSD wires, MTI "Hammer" cam, ASP underdrive pulley, Hooker LTs, Hooker ORY, Comp 918s, TR pushrods, UMI Sfcs, UMI LCAs, NGK TR55s, Hotchkis springs
