ok where can i get a good clutch from that isnt expensive? so far i priced tehm from summit, jegs and LMPerformance.com. i want something better then stock so i looked at the spec stage 1 but its 275 from LMP.com, hayes is 240,(from summit) and jegs was 236(zoom) any1 got any recommendations? the stores around here want 200-215 for a stock clutch. mine is just totally wasted, ill let off of it, and it will slip some more be4 it will grip
cluthes and where to get em
I've read alot about the Spec clutches and everyone that has had them installed likes them alot. When I had my clutch replaced I got a good deal on the stock part so I went with that. Ive put over 6000 miles on it already and it grabs just as hard as when I had it done. I saved some money and the performance of it has been great. I got a new flywheel also, you may want to consider doing that as well.1996 Z-28 6 speed, Airfoil, K&N FIPK, Flowmaster muffler, Motive 3.73 gears, BBK shorty headers, cut-out, LS1 Driveshaft, no power options (Rare), Prothane tranny mount, MSD 8.5mm wires, Accel U-Groove Plugs, Chrome hurst short throw, TB Bypass, ES Torque arm mount, BMR subframe connectors (weld-in), Lt4 Knock Module, Descreened MAF, '02 SS wheels, Pioneer HU, MTX & JL amps, 2 12" JBL's, T-Top Conversion!
Except me. POSOriginally posted by blackthunder50I've read alot about the Spec clutches and everyone that has had them installed likes them alot.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
I pulled out my Ac Delco books and found the clutch kit for an 88 Trans Am to be part #381151, the flywheel is #388022 which you will probably be able to resurface like you said. There was a service bullitin in the book stating that when replacing the clutch in your cars year to check the clutch cover mounting bolts working themselves loose. Hope this helps1996 Z-28 6 speed, Airfoil, K&N FIPK, Flowmaster muffler, Motive 3.73 gears, BBK shorty headers, cut-out, LS1 Driveshaft, no power options (Rare), Prothane tranny mount, MSD 8.5mm wires, Accel U-Groove Plugs, Chrome hurst short throw, TB Bypass, ES Torque arm mount, BMR subframe connectors (weld-in), Lt4 Knock Module, Descreened MAF, '02 SS wheels, Pioneer HU, MTX & JL amps, 2 12" JBL's, T-Top Conversion!
well i think ill put back in there what is in there now. also is the 13lb flywheel they have worth it? or am i just better off witht he factory one? im looking for some better ETs in the 1/4. i kno the aftermarket flywheel my buddy put inot his GTI dromed him from a 15.2 to a 14.9
