ok im finally going to put on my headers. I have hooker long tubes with the places for the 02 sensors. I have heard that you need to get 02 extensions or something. Where can I get them, how much do the cost ect...
I'm not sure what i need to get. Can anyone give me the part number.
125-109009 Oxygen Sensor Extension, 42" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109007 Oxygen Sensor Extension, 24" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109006 Oxygen Sensor Extension, 12" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109011 Oxygen Sensor Extension, 24" Flat 4-Pin (Front Sensor on 1994-1997 F-body, Front & Rear on 1994-1996 Impala SS) $25.00 Buy Wish
125-109002 Oxygen Sensor Extension, 24" Single Wire (Front Sensor on 1993 LT1 F-body) $25.00 Buy Wish
125-104035 O2 Simulator (Single) - 1996-up V8 F-body/Corvette (2 required) - OFF ROAD USE ONLY $44.99 Buy Wish
If you are not putting on cats behind your longtubes, you will need 2 of the simulators to replace the rear O2 sensors your car currently has. If you are putting a catted y-pipe on, you will need some fairly long rear O2 extensions.
You will need the 24" front O2 sensor extensions to reach the O2 bungs on the headers.
ws6store.com has it for 16 bucks and afterthought has 02sims for 34 bucks
http://www.afterthoughtsauto.com/o2sim.html thats for the o2 Simulator Connector Chart i don't know what you have on your car but on ls1 is type 1.2001 Trans Am WS6 M6
For the primary front sensors:
If you are not running cats, you'll need two of these in place of the rear sensors:
