NGK is the way to go, but you could also use Autolite. I have Autolite's in my car (96 LT1) only because they didn't have the NGK's I needed for nitrous. I never changed them to NGK because LT1 spark plugs should only be attempted once every lifetime, because there is only so much God can forgive when it comes to cursing
You're tellin' me lol . I still have to dig that wrench out of Craig's wall lol
The way I see it, if you're gonna do it, do it right. You can get the NGK plugs from Summit if a local store doesn't have them, and you'll have them the next day with ground shipping (which is free ). Here's what Summit has for the NGK plugs...
the first time i did plugs and wires it took 3 people 5 hrs ! now since my blower ( wich is a whole nother story, ive had lots of practice ) ive got plugs down to 3 hrs. i have a friend who asked me if i would do his . . . . i told him i would rather change the motor
Last time I did the plugs, I got all 7 of them out from the top
That # 6 plug was just impossible so I had to yank the y-pipe to get it out.
I hate to think about plug wires. the first time I did those, I looked at it for about 2 hours from under the car and never did figure out how to route the new ones in let alone get the old ones out of there - that space near the power steering pump. I put new ones in during the blower/header install and used 2 sets to get the lengths to route them in a more sane way that would also work with the headers. I am going to make a custom set next time.
The trick with the wires is to remove the alternator and loosen the power steering pump. In my case, I took all the bolts out of it so I could get it out of the way. You can run new wires in the same spots, it just takes some finesse to get it done. I have Crane Firewires in the bird now (which by the way, will never come out because I'm not doing that crap again) and I used all the factory holders.
I've got to do an AC compressor swap along with a new Optispark and changing to the electric water pump, and I'm seriously considering pulling the cradle out this time. If I do that, I'll repaint the motor, fix the classic LT1 intake leak the right way, and put in new plugs while it's out. Of course that will snowball into 409 stroker motor with twin turbos, direct port nitrous, etc. etc......
The trick with the wires is to remove the alternator and loosen the power steering pump. In my case, I took all the bolts out of it so I could get it out of the way. You can run new wires in the same spots, it just takes some finesse to get it done. I have Crane Firewires in the bird now (which by the way, will never come out because I'm not doing that crap again) and I used all the factory holders...
