I picked up a bottle of synthetic brake fluid and a mightyvac.
I know how to bleed the brakes in general, but should I be bleeding the ABS module also? Is it enough to just bleed the 4 calipers until I see fresh fliud, or do I also need to do something special for the ABS module? I want to make sure I get out all the old fluid.
First, I plan to use the mightyvac to suck all the fluid out of the reservior. Then, I'll fill it with new fluid. Then I'll bleed each of the 4 calipers until I see clean fresh fluid. I'm just not sure what to do about the ABS stuff.
