I just replaced the brakes, front and rear, (Pads only, rotors were turned) after 93,675 miles. Is this normal, or do I just never use my brakes? In addition, clutch has been checked and is fine, so can't just be engine braking from downshifting that gave me long brake life. Any thots or comments?
brake life
clutch is no shock, they should last the life of the car. the one in my acclaim has 145K on it and still going strong. as for brakes. they coulda been replaced at some point in time2009 Honda Civic EX- the daily beater
Depends on what type of brake pad is used and driving style. If you use the brakes hard often and have an inexpensive pad, they can only last 10k-20k miles. If you have a quality pad and don't use the brakes hard very often, they can last 40k-50k miles sometimes more.
The previous owner most likely had the brakes changed before you bought the car.
Originally posted by 88bird5spdclutch is no shock, they should last the life of the car. the one in my acclaim has 145K on it and still going strong. as for brakes. they coulda been replaced at some point in time1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
