Factory Car Alarm Problem
  • Factory Car Alarm Problem
    I decided to install my o2 simulators tonight, disconnected the battery first, unplugged old 02 sensors, installed simulators and reconnected battery.
    Now I did not bother to set the alarm, while going inside to pay for the lift bay here at fort bragg. So when i got home,i went to arm the car, like i always do and nothing! So I press all buttons on my key fob and nothing happens still. So i arm the car, by pressing the power lock button twice. Unlock the door with the key, and alarm goes nuts. So i pop the hood, disconnect battery to get it to shut up.
    So I disconnect batter, thinking maybe it was not tight enough or something to that effect, re-connect it, still nothing. Then i searched on here, and there was a thread that said to disconnect battery, pull fuses and reconnect battery. Well i sort of tried that, i cannot locate the fuse for the alarm. I did however pull every single fuse i could find and put them all back in.
    Now I have no keyless entry and no car alarm, i am not going to disconnect and reconnect battery just so the alarm is on by pressing the door lock twice.
    Any suggestions on what to do? I also tried turning the ignition key a few times on and off, just out of curiosity.
    Traded in: 1998 Z28
    This might help you out..
    http://www.ls1camaro.net/sections.ph...ticle&artid=49
    96 Camaro Z28/A4,Vortech elbow,Moroso CAI,Flowmaster.Addco PHR,LCA,160* Stat,pcmforless,1LE Driveshaft,1LE A/C delete pulley,1LE Front sway bar,Strut brace,sub frames, LT4 knock module,255 lph pump,Cutout,
