Found what might be a good deal on a WS6 32mm front sway bar. WS6 did have a 32mm sway bar right? I may be able to get it for $50. What do you all think? I've been considering getting a front sway bar and rear lower control arms.
Sway Bar Question...
To answer your question, yes. You'll want to locate the appropriate 19mm 1LE rear bar or the car will not quite be as balanced. $50 is good! My 94 V6 has the 32/19 bars and wow! what a difference. I'll bet this car will out handle my Z and WS6 easily. Those bars combined with the lighter front end because of the V6, this car is wicked in the turns. The front bar won't help you at the drags. It will limit front end travel and it's heavier. For the drags, you might want to disconnect the end links from the lower arms.
I thought V8's already had a 19mm rear sway bar.
Was the 1LE solid and Z28 hollow? Or maybe you're talking about '93/'94 1LE's that got a 21mm rear...
Joe K.
'11 BMW 328i
'10 Matrix S AWD
so if i was gonna change my sway bars from stock with the mods listed below whet would be a good choice
1994 Z28 stage 2 intercooled procharger, P-1sc, 6lb pully,42lbfuel injectors,255intank pump,1 3/4headers,highflow cat, borla ajust. cat back,chrome moly LCA,chrome moly ajust. panhard bar, Kenny Brownweld-in subframe conectors, built trans. kevlar lined 2600 stall, kevlar clutches, hardend parts,,built rearend; moser axles, eaton posi, richmond 3.42 gears, rare ROH ZR6 17* 9.5 wheels, custom computer tune with laptop and LT1edit , 380rwhp 395rwtq , 60' 1.71, 1/8th 8.00,1/412.60@109mph
