Tonight while going up a steep mountain on the way back to school my car started feeling a little sluggish. By the time I was near the top I had a noticable stumble all across the RPM range. I pulled off turned my lights off and looked under the hood. I didn't see any arcing until I happened to look around the intake elbow and noticed my coil wire arcing badly. It looked like a strobe light was right near where the coil wire plugged into the opti. Do I just need to replace the wire and be done with it or is there anything else I should look at?
Arcing at the coil wire
The wire would be a good start.
Originally posted by 94 formulaTonight while going up a steep mountain on the way back to school my car started feeling a little sluggish. By the time I was near the top I had a noticable stumble all across the RPM range. I pulled off turned my lights off and looked under the hood. I didn't see any arcing until I happened to look around the intake elbow and noticed my coil wire arcing badly. It looked like a strobe light was right near where the coil wire plugged into the opti. Do I just need to replace the wire and be done with it or is there anything else I should look at?
I would replace all the plug wires. It is likely time.
Plug wires don't have 4k miles on them yet. I changed plugs and wires when I put in the new engine this summer it was a lot easier routing them and putting in plugs with the engine out. The coil and opti don't have 5k miles on them so I guess the coil wire is the last origional piece of the ignition left I just overlooked doing that with the rest.Originally posted by Joe 1320I would replace all the plug wires. It is likely time.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
I have also seen instances of the metal boot protectors causing a grounding of the ignition energy. Mine was arcing at the coil pretty badly until I removed the boot protectors and replace with taylor firesleeves. Not saying that is your problem, just be aware that it can happen.Originally posted by 94 formulaPlug wires don't have 4k miles on them yet. I changed plugs and wires when I put in the new engine this summer it was a lot easier routing them and putting in plugs with the engine out. The coil and opti don't have 5k miles on them so I guess the coil wire is the last origional piece of the ignition left I just overlooked doing that with the rest.
Originally posted by Joe 1320I have also seen instances of the metal boot protectors causing a grounding of the ignition energy. Mine was arcing at the coil pretty badly until I removed the boot protectors and replace with taylor firesleeves. Not saying that is your problem, just be aware that it can happen.
I took my boots off when I did my headers last year. They were almost touching the boots and I figured that may cause arcing. I periodically check my wires just to make sure
have burnt and so far they look fine.
