I am in need of a really good head gasket for a 91 super coupe. It keeps poping the felpro one. Is there a good company that makes a MLS or straight up brass one? Felpro and Mr. Gasket dont make HI-Pro gaskets for this car.
NFB: 91 Super Coupe head gasket
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Tags: None
What is a "super coupe"??Tracy
Thanks Ill look into that, Im not up on my boost as im more of a NA guyOriginally posted by Joe 1320That is the model with the supercharged V6.
You could have the head o-ringed.
It's a pretty common practice on high boost engines.
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
hahaha...it's a Thunderbird.Originally posted by Joe 1320That is the model with the supercharged V6.
Actually, you have a couple of options. If you were doing the whole motor, you could O-ring the block or if you're just freshening the upper end, you can O-ring the head. The only real downside is that tuning needs to be dead on. The headgasket is meant to be sort of the safety..... detonation will push out the gasket before anything else. If you o-ring the the heaq or block, that safety is gone and the next thing to let go is probably a bearing, rod, piston, etc. Careful attention to tuning is the key, then it is very safe.Originally posted by DeWynterThanks Ill look into that, Im not up on my boost as im more of a NA guy
Are you sure the heads are flat? I've seen FelPro gaskets take a lot of abuse.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
