After I got back from Vegas last weekend, I noticed that my car turns too many times before it actually turns on when I crank it. Sometimes it takes as long as 3-4 seconds to start, or a couple of tries. It happens almost every time I try to start the car whether the engine is warm or cold. There are no SES lights or codes. I thought maybe the fuel system but after a filter change, it still has trouble. The wires are pretty new and the coil and MSD 6A is new as well. Everythings looks fine. A Tech 2 scanner test showed no DTC, and turning off the injectors one by one showed that they were all working as well as the EGR. O2 sensors showed the following:
Bank 1 Sensor 1 80-833mV
1 2 230 mV (constant)
2 1 70-820mV
2 2 180 mV (constant)
IAT 114 F
Ignition 13 degrees (Idle)
No Misfire data. What could it be? Opti has 82K miles, car has 108K
2 1 70-820mV
IAT 114 F
for the fuel system to pressurize before trying to fire it? Have you checked the fuel pressure? Checked for vacuum leaks?
