i drove my moms chrysler 300 05 and it was so smooth awesome suspension i just wondering if my trans am can be smooth like that even hit a bump. any suggestion?
smooth
smooth
2001 Trans Am WS6 M6
Tags: None
anything is possible if money is no object. The entire suspension must be tuned more for ride quality rather than handling. If that is a direction you wish to go, you will lose a fair amount of handling as a trade off. Start with springs with a soft rate, same with the shocks, lose the low profile tires and use something with a smaller wheel and considerable tire sidewall height. All these items tend to absorb the energy rather than transmit it though the chassis.
