I just bought a 2002 Z28 w/ 42K miles. The ac has been running perfect. However recently we have been have rapid changes in weaither, so I used the heat one day and ac the other. Well today I go to put the ac on, but it is stuck on heat. I pop the hood and the condenser is freezing, so I can tell everything is running right. What could possilby be wrong, and is this a common problem?
Air Conditioner on 2002 Z28 Stuck on heat.....
Check both sides of that cable. It could also be in the dash controls where the cable hooks up to the controls.
I think this is actually more common of a failure point. I had the same problem on my 93. I can't remember if it was it or one of my other GM cars, but I ended up just melting a new mounting hole in and hooking it back up. Worked fine.
Originally posted by Joe 1320There is a cable that runs from the dash controls to the air mix door, located in the passenger side footwell. That is what controls the mix of hot and cold air. You'll need to reemove the lower underdash panel for access. That is the likely culprit.
