when i bought my 97 camaro 3.8L V6 Y87 it was throwing two codes.
The first was p0302, cylinder two misfire. And an ignition code that relates to the cylinder two misfire (im not sure of the exact code). Since the purchase date i have fixed all misfire problems (coil packs, spark plugs, spark plug wires, thermostat, water pump, and radiator). The car drives like it has 50K on it, and not the 100K that it actually has. I feel no misfires at any temp, any RPM range, or any amount of load. I pulled the PCM fuse, ive disconnected the battery for 10 minutes, and the light is still on. I'm conviced that there is no more misfire. The computer was replaced roughly 30k miles ago, but id image the car was driven with the misfire for a decent amount of time. Could this be the computer, or someother problem?
