Hey everyone, I just joined today and hope I can get some help on this issue. Have a 99' T/A (5.7L) and have noticed a knocking/pinging sound (yes I got that description from the Haynes) when I get on it. Some times are worse than others, and some times I don't hear it at all? The sound is exactly like the sound you would hear when the timing was out on cars that used to have distributor caps, but don't think you can adjust timing these days. Also have noticed what seems to be a "whistling" sound after I hit the gas and then let off it? Power steering pump? I know there are folks here with 110% more knowledge of motors etc. than me, so I would appreciate any help I can on any of these issues. I wanted to check my vacuum but can't seem to find the right spot to hook up the gauge to on the intake? Thanks in advance...
Dale
Dale
(it will smoke up the neighborhood so do this where it won't cause issues) . Twice a year is what I do, and I always have a bottle on hand. Top end cleaner should be considered, regular maintenance for LS1's (btw my pinging would develop in 6th gear, under acceleration...then it would migrate to 5th, then to 4th...then be noticeable at any gear when I accelerate)
Just accept it will whine and keep an eye on the fluid level. The fluid level should not change (unless you auto-x - that's when I noticed a fluid drop)
