The brights switch doesn't click and I have to hold it back manually for them to turn on. Any fix?
Brights switch not clicking
I had what sounds like the same problem. The switch is good but The plastic around the switch became lose. So I just put a pinch of JB weld where the plastic base meets the steering colum. It has held for several months now. This is not proper fix of course. But it gets the high beams to click on without having to use two hands.96 Camaro Z28/A4,Vortech elbow,Moroso CAI,Flowmaster.Addco PHR,LCA,160* Stat,pcmforless,1LE Driveshaft,1LE A/C delete pulley,1LE Front sway bar,Strut brace,sub frames, LT4 knock module,255 lph pump,Cutout,
Hmmm....I just replaced my ignition switch a few months ago...maybe I shoulda done the dimmer switch as well .....its a bit of a PIA to drop that column....
1 tip though, when you undo the steering shaft joing in the engine compartment, put some tape on the shaft before loosening the joint so you know how far it has to be inserted when you put everything back together.95 Z28, A4, 3.23's and some other stuff....
Originally posted by 4THGEN ZHmmm....I just replaced my ignition switch a few months ago...maybe I shoulda done the dimmer switch as well .....its a bit of a PIA to drop that column....
1 tip though, when you undo the steering shaft joing in the engine compartment, put some tape on the shaft before loosening the joint so you know how far it has to be inserted when you put everything back together.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
