ok. . . . its winter now in maine just put the wip away now its time to change somthing i havent, where is a good place to buy a crate engin ? im going to keep my procharger im thinking low compression HIGH boost 12 - 15 lbs big boost ap. cam, hogged heads ( i dont know if stock heads can take what im going to do to them ) so maybe AFR i may start with 10 - 12 lbs BUT i want this motor to be BULLIT PROOF just in case i go higher later it has to be able to take 750 crank HP i would be greatfull for any help thank you -Kevin
crate motor ?
crate motor ?
1994 Z28 stage 2 intercooled procharger, P-1sc, 6lb pully,42lbfuel injectors,255intank pump,1 3/4headers,highflow cat, borla ajust. cat back,chrome moly LCA,chrome moly ajust. panhard bar, Kenny Brownweld-in subframe conectors, built trans. kevlar lined 2600 stall, kevlar clutches, hardend parts,,built rearend; moser axles, eaton posi, richmond 3.42 gears, rare ROH ZR6 17* 9.5 wheels, custom computer tune with laptop and LT1edit , 380rwhp 395rwtq , 60' 1.71, 1/8th 8.00,1/412.60@109mphTags: None
Be prepared to throw down some loot for a truly bullet proof shortblock. Call Sam at Combination Motorsports. They are quite possibly the most knowledgable LT1/LSx engine builders in the country. 702-798-8504, www.cmotorsports.com
