Ive been getting a bad noise from my rear end in my 2000 trans am with posi. 3.42 gears. its all stock ive been wanting to replace with a moser 12 bolt but are currently broke. The yoke has alot of play in it. I mean i can move it around and fluid leaks out. I was woundering what you guys think the problem could be inside or is it just a worn bushing or something.
cost to repair?
Difficlulty to do myself?
cost to repair?
when acc or cruising. also a littel vibration on high way. the yoke has a bit more play then i think it should have. I think that may be the problem. the extrea play lets a bit of fluid out, more then it should. The car only has 55k on it but i push her to her limits often. hard to explain what it sounds like but its loud and apperent.
