My car runs and drives fine, however after the header install when i give it gas it has a ticking sound that sounds like an exhaust leak. We used those paper gaskets, how can I tell if they are leaking or if its a plug leaking?
How to tell if header gasket leaks?
Tags: None
From what i hear those paper gaskets are no good, that ticking sound definately could indicate a header gasket leak i had one on my car nad thats exactly what it sounded like. Do a search here for some good gaskets there was just a thread about them recently.-Dan
Headers definetly have a different sound to them than stock but a ticking sound especially one that increases with RPM points to a leaking gasket. I used the paper gaskets when I installed my pacesetters and they didn't stay on for a week. I had the ticking sound you are descibing and when I removed the gasket you could see 2 areas they were leaking on the drivers side and 1 on the passenger. I replaced them with felpro and they worked fine, I used them again when I swapped my headers onto my new engine. I would recommend the felpros but from what I've read on here you can't go wrong with Percys dead soft aluminum.Originally posted by blackthunder50My car runs and drives fine, however after the header install when i give it gas it has a ticking sound that sounds like an exhaust leak. We used those paper gaskets, how can I tell if they are leaking or if its a plug leaking?1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
