My summer expectaitions, during this summer my goal is to hit high 12's to low 13s on street rads and on pump gas, heres some things that are on the agenda so far, borla cat back, ram air hood/functional air box, headers, 1.6 rockers, what should i expect out of this? hoping at least LOW-mid 13s. comments and suggestions to help me reach my summer goal appericated!
summer goal
Thats definately a good way to start exhaust and intake mods are always a good palce to go, 4.10 gears would probably be helpful as well, and then after all of that stuff is done, a good tune from pcmforless or madZ28 would help out as well. As far as other suggestions I'll let some of the others handle it-Dan
I think if you add gears you will be there. I had pretty similar mods, plus my car was lowered, except that I did not have headers or 1.6 rockers and ran a 13.68.
I think with a little better traction and those couple extra mods you'll be close. Not sure about high twelves though. More like lower 13's. A lot depends on the headers. But, every car is different.
13.685@102.11
you wont get into the high 12's without a cam and maybe some headwork, along with good headers, 52mm tb and the precise tune.
With those mods there I'd look for around a 13.4-13.6 there are a ton of variables. As thenudge876 said a tune would really help especially with the 1.6 rr's. If your thinking about doing a cam I'd hold off till you have the money for head work to go with the cam. Also some traction mods such as sub frame connectors, LCA's, upgraded panhard bar ect will really help lower your 60 footer and that'll reduce your e.t.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
Ram air, free mods, assorted bolt ons, 1.6 rockers, SLP Shorties, Random tech high flow Y pipe, borla, aluminum driveshaft, 3.73s, suspension mods, tune, got me to a best of 13.0 at 107 on radials. That's with an automatic and a stock stall converter. Give me some ET streets and a 2800 converter and I'm in the high 12s easy. Suspension work and sticky tires does wonders for hooking up.
Originally posted by Joe 1320Ram air, free mods, assorted bolt ons, 1.6 rockers, SLP Shorties, Random tech high flow Y pipe, borla, aluminum driveshaft, 3.73s, suspension mods, tune, got me to a best of 13.0 at 107 on radials. That's with an automatic and a stock stall converter. Give me some ET streets and a 2800 converter and I'm in the high 12s easy. Suspension work and sticky tires does wonders for hooking up.
13.410 @ 102.66 with A4 3.23 stock stall, stock heads & cam. My mph suffered alot due to knock retard pulling timing. Previous best was 13.466 @ 103.85 w/a 2.078 60' pulling timing from 93mph through the trap. I think if I could finally get the knock issue resolved 13.2's would definately be possible with what I have now.
Finally found the right settings for the rear suspension to hook. Front end is lifting pretty well.1995 Firebird Formula
gears.. yes I wouldn't mind maybe some 3:73s, also what could I expect to pay for a tune from madz28 or pcmforless?..Thanks for the all the respones guys, I have got some thigns to think about!1995 Trans Am, 75k, T-tops, 6-speed, Pace Setter Long Tubes and ORY, Custom Flow-TECH Terminator Exhaust, Hurst Shifter, Cags plus free mods........Up next; Tune and CAI
Originally posted by wolfmanyour'e one of the very few though Joe..ive been following this stuff a long time, as you have... most guys dont see below mid 13's with that stuff....
I definetly agree with you ken that not many LT1's see those numbers with those mods. Joe didn't yours run in the 13's stock?1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
