I guess it would depend on convection. With lots of turning, stopping & accelerating, it may actually transfer the cool water around pretty well. Oh well, too hard to figure out.
removing thermostat
So what would be better..
1.Buy an aftermarket trans cooler and bypass the factory cooler?
2. Use the factory cooler with an aftermarket one?96 Camaro Z28/A4,Vortech elbow,Moroso CAI,Flowmaster.Addco PHR,LCA,160* Stat,pcmforless,1LE Driveshaft,1LE A/C delete pulley,1LE Front sway bar,Strut brace,sub frames, LT4 knock module,255 lph pump,Cutout,
Heres another issue with not running a thermostat. Not running a thermostat is like tryng heat up a hot tub. It may take awhile to get warm but once it heats up you can't cool it down because now all your doing is recirclating hot coolant back into a hot engine even thou it passes through a radiator. The idea of the thermostat is to hold the coolant within a certain temperature range.99' TA 347 H/C MS4, QTP headers, 9' 4.11's
11.05@ 125 on motor, 9.80 @142 on nitrous
Originally posted by smokeum99taHeres another issue with not running a thermostat. Not running a thermostat is like tryng heat up a hot tub. It may take awhile to get warm but once it heats up you can't cool it down because now all your doing is recirclating hot coolant back into a hot engine even thou it passes through a radiator. The idea of the thermostat is to hold the coolant within a certain temperature range.
The fans set the upper temp limit, not the thermostat. Hot=open, cold=closed, it has no way of controlling flow when above its opening temp.1996 T/A - BBK headers & throttle body, K&N filter, 1.6:1 Comp Cams Pro Magnums, Warbird hood w/ SLP Ram-Air
You've been fooled by urban legend. Anyone with a basic understanding of thermodynamics and heat transfer will be able to understand why this not true.Originally posted by smokeum99taHeres another issue with not running a thermostat. Not running a thermostat is like tryng heat up a hot tub. It may take awhile to get warm but once it heats up you can't cool it down because now all your doing is recirclating hot coolant back into a hot engine even thou it passes through a radiator. The idea of the thermostat is to hold the coolant within a certain temperature range.Fred
