Ok. My friends 95 trans am died on him on the way to my house. He said the abs light was on, then a little wihle later a whole lot of lights came on and it died. Wouldnt start back up. I went and got the batter out of my car and put it in his. Started right up, but the voltage meter was reading still a bit low. I personaly think its an alternator problem but I am not for sure. Also on the drive back the idle fluxuated a little bit. Any help appreciated. Thanks in advance.
possible battery/alternator problems
Well I got home and on the way home it ideled fine. I did notice the voltage reading had a study decline all the way home. Any suggestions, comments apperciated!Originally posted by 96CamaroOk. My friends 95 trans am died on him on the way to my house. He said the abs light was on, then a little wihle later a whole lot of lights came on and it died. Wouldnt start back up. I went and got the batter out of my car and put it in his. Started right up, but the voltage meter was reading still a bit low. I personaly think its an alternator problem but I am not for sure. Also on the drive back the idle fluxuated a little bit. Any help appreciated. Thanks in advance.1995 Trans Am, 75k, T-tops, 6-speed, Pace Setter Long Tubes and ORY, Custom Flow-TECH Terminator Exhaust, Hurst Shifter, Cags plus free mods........Up next; Tune and CAI
Test the alternator. This is my "poor mans" load test. Crank the car without anything on then disconnect the battery. Then rev it to ~1500 RPMs. Then start turning on things. Turn on the A/C, slowly turn up the fan. Then the lights then high beams then rear defroster. If the engine starts missing or dies at any time during then the alternator or regulator is bad.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Put the new alternator in...held good voltage for about a min and went back to crap. Now has the dang battery gone out
? Idk, gonna try different battery and see what happens. If this new alternator has gone bad already atleast its under warentee
. But would not be too happy about putting another one in lol.
96 Camaro Z28, T-tops, 6 Speed, Slp CIA, Flowmaster cat-back, 3:42 gears
Ok well found out it wasnt the battery....When I put the alternator in, while I was driving it the ground wire became disconected beings how I had toput a new end on it. And could that have caused the alternator to have gone bad? Not a big deal if it did because its under warentee
. But just wanted opinions on this.
