i was wondering if anyone knew were i could get some new head lights i want the bright white or the bright blue. thanks in advance for any help.
Head Lights
Head Lights
99 T/A WS-6
88 IROC-Z, ZZ430 CRATE MOTOR, Flowmaster exhaust, MOSER 12-bolt with gears, and a few other mods.Tags: None
not for Birds my friend... been looking for awhile. We're stuck with the Halogens.
I'm pretty sure you could customize a halogen sealed beam with a h2 bulb, but I never tried.
You need to replace the sealed beams for H4 head lamps from Hella brand. Then, you will be able to install any bulb you want, even the Bi-xenon's (High/low beam). I have been looking for upgrade the headlights because, as you already know, the stock ones are deficients. My 97 Trans am has installed the H4 Hella with bright bulbs for now. My goal is the Bi-Xenon.
www.rallylights.com is a reliable place to look for...
Good luck
Dochidalgo
http://www.rallylights.com/hella/165mm_lo.asp97 A4 Pontiac Firebird Trans am with $everal mod$
99 T/A WS-6
