hey guys im just doing some shopping around(and a little dreaming right now) but i found two different companys that offer kits to convert from a auto to a 5 speed they're pretty much the same kit just two different compays but one says "70-81 Camaro/Firebird: The stock TKO 500/600 will not fit in this car correctly! Keisler Engineering owns a ’79 Trans Am for development work and we have found that without our custom shift position there are serious clearance issues for the tunnel, console and driveline angle. All the competition can offer for your car is an external offset, a simple bent piece of metal sticking out in zigzag fashion from the top of the shift tower. An external offset shifter interferes with the floor and negatively affects the shift geometry. In fact, there is only 1.5” of room to fit the original TKO shift tower in the tunnel. Consider trying to fit the entire shift tower, and the base for the shift handle in 1.5” of space. Simply put, this is too much mechanism in too little space. If you lower the transmission in the tunnel to accommodate this mechanism you will ruin your driveline angle, which in turn will cause noise and vibration while reducing the life of your u-joints, transmission output bearings and differential. The Keisler PerfectFit kit for this car features a custom tailhousing with a true internal offset that provides the factory-correct shift position, driveline angle and tunnel clearance with no cutting or modification to the car. We are the only company that provides this." and that from www.keislerauto.com which i've heard some bad reviews about from ppl on other forums about the coustomer service and getting parts on time
while another company that i have heard good things about offers this as a solution
but its not required to make the car work cause its only optional but i worry about if keisler was right about the angles being messed up or if they were blowing smoke to get ppl to buy their product the other company is
www.classicchevy5speed.com
i work in retail and i don't like dealing with ppl that are know to be [EDIT] but i don't want a bad product because the ppl are nice. you guys think its smoke or is kisler right?
![](http://classicchevy5speed.com/images/McLeod1offset_parts.jpg)
