World Products appears to have faith in the future of the GM Gen III engines.... they are now offering (from their advertisement in National Dragster):
Warhawk LS7X Block:
-454ci capability
-improved main bearing priority oiling system
-mounts to LSx or conventional SBC motor mounts
-dry sump capable
-Billet steel CR-5 style main caps
-Provisions for 2 extra head studs per cylinder
-9.240" and 9.800" deck heights
-4.000" or 4.125" bore with 0.100" dry sleeves
-crankcase clears 4.250" stroke cranks
-all LSx components direct bolt-on
-priced 35% below a C5-R block (making it about $4,000).
Warhawk LS7X 12* Heads:
-Upgrades over both C5-R and LS7 heads
-2 extra studs per cylinder
-255cc intake runners, 64 and 72 cc C5-R style chambers
-12* rocker stud angle to match valves
-valve covers raised 0.600" to clear virtually any valve train
-LS7 intake manifold compatibility
-C5-R style exhaust ports
-2.200" I/1.600" E valves
-12* valve angle, using all standard LS7 valve train components
-366-T6 aluminum with 0.750" deck.
As if the LSx family of engines doesn't already have a ton of performance stuff available..... there's going to be some mind-bending power made with these parts. And without the Gen III's inherent problems of oiling and keeping the heads on the block!!!
Warhawk LS7X Block:
-454ci capability
-dry sump capable
