It is absolutely amazing how many problems old motor mounts can cause. As they age, the rubber dries out and shrinks. After enough time, the mount no longer insulates the engine vibrations from the chasis as it should.
When i got my V6 car it had bad motor mounts. That thing would rattle the teeth out of your skull. The entire interior resonated with rattles. After replacing the motor mounts, it is smooth as silk. I paid $35/each for them at the stealership, but I have a wholesalers license and get a pretty deep discount on all my parts. I know all the folks in the parts department by name.
Installing the mounts in the V6 car was a breeze. I didnt have to remove anything. I did them 1 at a time, jacking up the motor with a piece of wood and a floor jack. I just jacked the motor up as far as it would go and I had plenty of room to work. It was a piece of cake!
I'm glad to hear you are getting the bugs worked out of your car. That is always my goal: a bug-free car. I should be able to give the keys to my wife and she should be able to drive it cross country without any issues popping up. It irritates me when a bug pops up and requires constant babysitting.
Also, when you're starting it, the mounts are so solid that the whole car rocks one way with the starter. I'm not sure if it normally does this with good mounts, but my worn rubber ones didn't. I'm amazed that the motor mounts, tranny mount and tq arm mount are all poly, yet it's still a smooth ride.
Whatever the case, I'd definitely recommend them if you need the mounts replaced.
