To begin, I have a '96 firebird with the 3.8l. This might be a long post, so I'll summarize it at the bottom.
Recently I have been having some major cooling system problems. December 28th I was driving back to work after lunch. Some guy in a civic tried to race me, so I had to show him whats-what. I downshifted to second and punched it. After my revs got up to about 5500 I reard a pop and there was steam pouring out behind me. I pulled the car over and got it towed home. That night I got under neath the car and discovered that it was my block heater that blew out the bottom of the block. I replaced it, refilled & bled the system then went to the carwash to get rid of the coolant so I wouldnt have to smell it burn.
On the way back from the carwash I start to smell coolant again about a block from my house. I look in the rearview and yet again, a lot of steam pouring out. I pull back into the garage and pop the hood. Turns out one of my heater core hoses popped off, well I think thats what its called. Theres two of them that come out the top of the engine of the front passenger side. Anyway, I put some RTV on the hose and popped it back on. I havnt had a problem since, untill today.
I was pulling out of my cousins apartment parking lot with my cousin in his stang right behind me. I lit up the tires and slid sideways out onto the street., making alot of smoke, or so I though. After a hundred feet or so I still saw smoke in my mirror and then I started to smell burning coolant again. I ripped a u-turn and we went back to the parking lot. I popped the hood and this time the other hose had popped off. So again, I applied some RTV sealant and put the hose back on, then filled & bled the system.
All this has got me worried now. Is there something seriously wrong with my cooling system? Everything else works perfect. The heat is working fine. T-stat is brand new & working, I tested it, but for good measure I replaced it tonight too. All the air is bled out of the system. I Let it get hot three times and after the second time, no air came out of the bleeder screw at all.
Anyway, what do you guys suggest I check?
Recap:
-December 28 I blew my block heater out of the block
-After replacing block heater I blew one of the heater hoses off of the engine (come out of the front passenger side of the engine near the top)
-Sealed it with rtv sealant & everything works great
-Today the other heater hose popped off the engine.
-Fixed it & replaced t-stat with one I tested.
-Block Heater & both hoses have come off during heavy acceleration
--Help!!
Recap:
--Help!!
