So, I'm thinking about replacing the brake lines on the Z with some Stainless ones. I'm wondering just how hard this is to do. Something I could attempt myself or would I be better off taking it in? Any other good mods I can do while I'm in the area? Thanks guys.
Brake line replacement
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Tags: None
It's an easy switch but you will need someone to help you bleed your brakes when you are done. The pedal will feel harder when you are done.Originally posted by Steve93ZSo, I'm thinking about replacing the brake lines on the Z with some Stainless ones. I'm wondering just how hard this is to do. Something I could attempt myself or would I be better off taking it in? Any other good mods I can do while I'm in the area? Thanks guys.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
How worried should I be about brake fluid getting everywhere? The last thing I need is to have to worry about the paint. Thanks for the quick reply JeffOriginally posted by Jeff 95 Z28It's an easy switch but you will need someone to help you bleed your brakes when you are done. The pedal will feel harder when you are done.
Steve
Mods
Mods
Mods
Any brake fluid that spills will spill onto the floor. You can use a bucket to catch it. You can even bleed them by yourself if you go spend $35 on a mightyvac. I just got one recently and dont know how I survived without it anymore. I'm not in the least bit intimidated by brake work anymore, bleeding the lines by myself is a snap.Tracy
Cool. I learned something today. That's always good.Originally posted by TraceZAny brake fluid that spills will spill onto the floor. You can use a bucket to catch it. You can even bleed them by yourself if you go spend $35 on a mightyvac. I just got one recently and dont know how I survived without it anymore. I'm not in the least bit intimidated by brake work anymore, bleeding the lines by myself is a snap.
http://www.mityvac.com/pages/products_bcbe.asp
Which one are you using?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
http://www.mityvac.com/pages/products_hvpk.aspOriginally posted by Jeff 95 Z28Cool. I learned something today. That's always good.
I got the 06820 kit.Tracy
Cool. I still have to replace the rear brake lines with the stainless braided lines on my car. I just haven't had time or when I did I didn't have someone to help me bleed them. Problem solved.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
If I had 17's I wouldOriginally posted by Cerwin Vega FanMight be worth doing a ZO6 upgrade while your down there.
lol
Steve
Mods
Mods
Mods
