Steering advice needed
  • Steering advice needed
    The car seems to wander just a bit on the highway. Just had an alignment done and it's the same before and after. The power steering fluid was a little low and I topped it off a couple months ago. That helped a little.
    I'm thinking about getting the system flushed and filled. What do you all think???
    Joe K.
    '11 BMW 328i
    '10 Matrix S AWD
    well if adding new clean stuff helped id say it wouldn't be a bad idea
    1990 Eagle talon TSI- daily driver
    78' firebird formula -350/350- stock...now dead
      What are you running your tire pressures at? The higher the pressure the more it will wander.
      You should read this article http://www.tirerack.com/tires/tirete....jsp?techid=47
        I had a sticking front caliper that made my car pull to the left...but you said wander, so that nullifies my post...
          It's slight, but there. I know it's normal to pull a little due to the slope of the road. I run my tires at the recommended pressure. I already checked that though.
          It's funny how you notice little things and later it turns out to be a problem. I cut a rear tire once. It took an hour for the tire to lose most of it's pressure, but I could feel it through the steering very slightly for the last 1/2 hour before it went. I remember thinking that I need to get it checked...then...boom!
          Joe K.
          '11 BMW 328i
          '10 Matrix S AWD
            my car does cuz of the cheapo 245 tires i have on the front for winter. it finds the crown or crack and boom its being pulled then lets go, its annoyance but dont bother me much
