ok started doing an engine swap on a 91 firebird with a 5.0 tbi and automoatic trans and need help with disconnecting the engine from the transmission i need pics, links and whatever info i can get
thanks
6 bellhousing 9/16" bolts, use a flex socket(has a joint to allow it to move around a bit), be4 removing beholusing, take of sheild and remove the 3 torque convertor bolts, it then should seperate from teh motor. need any more info, give a shout
edit: dont forget bout the TV cable and dipstick tube, and also any wires or lines that run to the tranny
