OK...slow day at work, so I'm "desktop" building again.
Anyway, I'm confused about Comp Cams. Specifically, I've read for years about the CC305 and CC306 cams, with the 305 being better suited to stock bore/stroke engines needing to still pass emissions.
Whether this cam is better than the LT4 Hot Cam for ported heads on a 4.10 equipped M6 needing to retain street manners and pass the NJ sniffer test seems to be an ongoing debate though. I don't mind a bit of lope, so long as it can pass emissions with the proper tune. I don't want to leave power on the table either.
Anyway, my question is, is the CC305 the same cam as Comp Cams new Extreme Energy series? PN 07-305-8 is the Extreme Energy cam. It seems to have the same .510/.510,(.544/.544 w/ 1.6 rockers) 220/230, 114 ratings as the aforementioned CC305, but I can't determine if theses are in fact the same cams.
What are you thoughts?
