My '99 has had this issue since I bought it. You hit the release and the hatch pops up a bit, but still catches. You have to hit the release, lift up a bit on the hatch, and hit the release again to get it to open. I've tried adjusting the rubber stops both ways, but it doesn't help. Any suggestions?
Rear Hatch Release
Do your struts seem to raise and hold up the hatch ok? Maybe they are tired. Also try cleaning your weatherstripping to be sure it is not causing it to stick.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Struts seem strong enough. I know they don't work as well in cold weather, but the car has this problem year round. It could be, I know they aren't too expensive to replace. I could always return them if it doesn't work!Joe K.
'11 BMW 328i
'10 Matrix S AWD
I got the same problem. I bothers the crap out of me, so I just pull the hatch up as I press the remote to open. I don't even try to release it while in the car, cause you have to go back and forth to release the hatch.
It's the weather stripping. You can hear you stick to the hatch, especially where it curves up. I tried to clean it, but it still sticks. I'm thinking of getting silicone and seeing if that don't help.
Yes, cold days make it worse...
If you can figure out a way to fix it, let me know. I'll do the same.
I have an idea!!
Adjust the latch down just a hare so the hatch closes more firmly.
The result will be a hatch that pops open just enough when you hit the button that it does not re-latch itself.
Ok, tell me I'm brilliant. I know.
I figured it out and my car doesnt even have a silly hatch!
Got it! Here's what we need....
http://www.installuniversity.com/ins...ease_fix_2.htm
Don't worry TraceZ...we still think you're brilliant!
Joe K.
'11 BMW 328i
'10 Matrix S AWD
Yeah, that would work too, but I'd try my idea first just because it does not require modifying the car from stock and is easier to implement. It should be able to work the way it was originally designed if everything is set up and asjusted properly.
They adjust the latch at the factory when the hatch's weatherstripping is new. As the car ages, the weatherstripping squishes down and does not fit as tight. As a result, the latch will need adjusting to release properly.
It makes perfect sense, at least give it a shot.
And yes, I am brilaint.
Yes, you are very bright Tracy
I could tell that from the projects that you do. I would recommend trying the adjustment thing as well. Make sure to mark the position of the locking mechanism first, in case you have to move it back. You can do this by using something as insignificant as a sharp nail.
Anyway, good luck
let us know how it turns out-
To be added soon-Firebird Graphic
Oh the glory!!! I know what I'ma gonna do when I wake up tomorrow!!! Lowe's here I come!
Man, ..., I can't believe how long it took for you guys to find this!
That was one of the first things I did to both of the 4thGen F-body's I've had.
Works pretty well, for a while, ...1) 2001 Pontiac Trans Am 10th Anniversary Firehawk
2) 2005 Pontiac Bonneville GXP
3) 2004 Pontiac Grand Prix GTII
4) 1986 Pontiac Fiero GT
5) 1996 Chevrolet Blazer
6) 1993 Harley-Davidson FXSTS Softail Springer
Condition Hatch Weatherstrip
My 2000 has the same problem but only during cold weather. I have conditioned the weatherstrip with Dielectric Silicone Grease and the problem has gone away. You can get the grease from the dealer. It's part number 12345579. This is also listed in your owner's manual under recommended lubricants for weatherstripping. Good Luck!1988 5.0 TBI Camaro 700R4 Transmission
2000 3.8 SFI Camaro 4L60E Transmission, K&N Air Filter, and Drill/Slotted Rotors all around.
