I have a problem with my SLP headers and the #5 wire (Taylor Spiro Pros 8mm). Ever since I had the flanges cut down, the #3 and #5 primaries are hugging on the fire sleeve and burning through. So I need an extra long wire to tuck into the loom under the primaries, then wrap back around and go into the plug...staying as far away as the header as possible. I guess then there are a few possibilites:
- Buy more wire and cut/crimp to elongate the wire?
- Buy and individual wire that's 6-8" longer than the current one (if they sell individual wires)?
- Use an 2 year old 7 mm OEM wire (maybe on that was previously used on #7 for the extra length)?
Which one is the best route? The cheapest is obviously to use the existing 7mm wire, but I'm not sure if a mixmatch is ok?
Thanks in advance
Thanks in advance
