My lt1 dyno results...Not too shabby, I think.
  • My lt1 dyno results...Not too shabby, I think.
    Just got back from the Superflo chassis dyno today. I made 3 runs with closed Borla (all thru the muffler) and three runs wide open Borla (full cutout).
    I had slightly better results using full muffler.
    My 1995 74K LT1 is near full bolt with the following mods:
    AS&M cold air induction with K&N filter
    Borla stainless steel adjustable catback
    RK sport 1/34 mid length headers
    Bullet muffler in place of catalytic converter
    Elite spark plugs OVC wires
    NGK iridium plugs
    Trick flow elbow
    52MM throttle body
    Throttle body air diverter
    Comp Cams 1.6 roller rockers
    LT4 valve springs and retainers
    March underdrive pulley w/ alt. pulley
    4.10 Ring and pinion
    1LE aluminum driveshaft
    TB coolant bypass
    160 degree t-stat
    Madz28.com tune
    I swear the Zaino helped too
    The Superflo STP corrected numbers were:
    301.5 RWHP @ 5400 RPM
    326.7 RWTQ @ 4100 RPM
    It is obvious from the results and the dark smoke that the A/F ratio is rich at 12-12.4
    I might be losing some power here.
    All in all I am very happy with the results.
    What do you guys think I can get in the 1/4 mile?
    That RWHP is decent considering your mods. With your T-56, that equates to roughly 350 HP at the crank.
    Does the shop where you dyno'ed it have the ability to tune your car while on the dyno? I can't see your pics BTW.
      Picture host server must be down at the moment.
      Yes they can dyno tune for around $350.
      I will contact madz28.com to see if they can get me atune that will lean the motor a bit, its running rich.
        Nice numbers indeed.
          Nice! That is about where it should be for those mods.
            Impressive all things considered. I would be very happy with that.
              ahh...the dyno. wish I could get my ride on a dyno. Great numbers by the way...
                Nice numbers indeed
                A question...what is a SuperFlo dyno and STP corrected numbers? And how does it differ - if at all - from a Dynojet and SAE corrected numbers?
                  With respect to the Superflow dyno, I need to differ to someone more qualified to answer.
                  This is all I can add:
                  http://www.sracing.com/Store/Chassis_Dyno/cdyno.htm
                  STP corrections are basically the same as SAE using a very slightly different calculation. It has been stated that the STP might add just a fuzz better numbers.
                    There are basically 2 benchmarks by which dyno operators will correct your actual HP numbers. There is what they call the Standard Correction (STP) which uses the following weather data as it’s benchmark: 60° F, 29.92 InHg, and 0% relative humidity. Then there is what they call the SAE J1349 Revision JUN90 which uses the following weather data as it’s benchmark: 77°F, 29.235 InHg, and 0% relative humidity.
                    Normally tuners and shops will use the standard(STP) correction. Obviously the higher pressure and cooler correction temps in accordance with the STP correction method will cause the output to be higher corrected numbers, but it is by far the most widely accepted correction method.
                    Sometimes they will use the June 1990 Revision guidelines by which to correct, but this is not near as widely used. The SAE correction will cause your numbers to be about 4% lower than the STP "Standard" correction.
                      As I replied on another forum where you posted this, the Superflow can be run in either inertia mode, emulating the Dynojet and producing similar figures, or in eddy-current mode, emulating the Mustang dyno. You need to find out which way they ran it.
                      If you just do the ratio of absolute pressure (29.92/29.235 = 1.0234) and absolute temperature ([77+460]/[59+460] = 1.0347), the STD would produce about (1.0234 X 1.0347 = 1.059) 6% higher results than SAE. That's a simplification.
                        Nice numbers - and nice car. I had a white 96 Z28 conv't only it had a white top. Loved that car!
                          Here's some good reading:
                          http://www.superflow.com/support/cyc...y.html#Inertia
