i am running a 98 Z28 with a vortech supercharger with 9 psi and its aftercooled, but im getting ready to do a tune up on it and im not sure what plugs to get, they say i should run a colder plug because of the SC, what is a colder plug. any info will help.
what plugs to use with a SC
MightyMaro666Tags: None
Most guys will use the NGK- TR6 plugs. They are gapped at .035 instead of the normal .050, which makes them burn cooler.
I have used the NGK plugs for a few years now and I am very pleased with them.
You can pick some up here:
NGK plugs
Randy99 TA "RBLUTA" - NBM, M6, Whisper Lid, SLP Fan Switch, 160* Thermo, SLP LM, BMR STB & LCA's.
Exactally what I ran on my 94.Originally posted by FRMLAV8
NGK plugs
Randy
I used to run the AC Rapidfire #3 on my old Powerdyne supercharged 93 Z28. I never had any problems at all. And I left the gap opened up at .045 because I was running a Jacobs Ignition box which needed the bigger gap.69 Z28 with JL8 factory 4 wheel disc brakes, crossram, transistor ignition, radio delete, heater delete - being restored
2000 SS Camaro daily beater
That was my choice as well, except I used an MSD6A. Worked well.Originally posted by JL8Jeff
I use NGK TR6. They are a cooler plug and resist detonation because the ground strap and electrode are shorter and dissapate heat faster. I've never had a problem with the NGK's.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
