How do you inspect waterpump for wear?
  • How do you inspect waterpump for wear?
    i pulled my waterpump yesterday and have a few questions... how do you inspect it for unacceptable wear? the impeller spins with a little bit of resistance but definately not seized or anything... the male and female splines seem fine but like i said im not sure what to look for for "wear" on these components... thanks...
    -chris
    Chris,
    I would verify that the bearing and bearing seal are OK. You'll know the bearing seal is shot if the pump leaked coolant out of the weep hole prior to you removing it. Next check the drive shaft for looseness. You shouldn't be able to move it side to side at all. Check that it is quiet when the drive shaft is spun.
    Warren
    96 T/A,WS6,M6
    79 T/A,WS6,A3,403
    72 442,W30,A3
    06 Vette,Z51,M6
      when i took out my water pump, the bearings fell right out.
      1996 Trans Am WS6
        Warren summed it pretty well. You can also pull the inspection cover to inspect the impellar and impellar housing.
        But.....since you already have it off, might as well just replace it.
          everything looks good on the pump, i would buy another one but $ is tight now and a new pump is like 150 from autozone-- thats a set of rockers idk i think im gonna try and reuse this one... thanks!
            The lifetime guarantee ones from Autozone are $65, pretty much the same at the other guys too. Since getting at it takes awhile, its pretty much a no brainer to get a new one.
            The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
              Originally posted by Warren Seale
              Chris,
              Warren
              This is the only way I knew my pump was dyin! Cause there was now water left in my radiator!
              Oh and a rusty puddle on my drive!
              Screaming Mad
              Car: 1994 Camaro, 3.4l V6
              Pace Setter headers & Y pipe, Flowmaster Z28 exhaust, K&N cone filter. modded 4l60e, trans cooler, strut brace, Eibach pro-kit
              0-60 7.74
              1/4 16.52 @ 85.3
              Bike: Suzuki GSXR K4 600, K&N filter,Rizla kit, R&G bobbins, Db screen, LED indicators
