Warning: Do not buy the chain store batteries (forgot exact brand) that are called "Nascar". Mine was from Kragen. They are vented in a location right next to your radiator and mine ate a hole in my 18 mo old radiator from battery venting fumes and acid.
Next:
My car is in a shambles and it is smog /registration time. Besides the radiator and coolant res, I need to change the opti (this will be my 3rd in 156,000 miles). I will also do plugs and replace the original wires.
Do all plugs get gapped at .050 even if the plug manufacturer recommends .060 for our application?
Do MSD8.5 fit the stock looms and routing without much trouble? (Although I am leaning towards stock since they held up so well for many miles)
Is it worth $40-50 to replace the original coil preventively? I have no reason to believe it is bad, but am replacing the rest of the ignition system. Does their performance degrade significantly over time, or do they typically work well up to failure? Same Q for original (150,000+ mile) EGR?
How should I go about fixing my torn drivers seat bottom (left hand side)? You guys know what I mean, every 4th gen in the salvage yard is ripped the same way.
If I were to get the LT1 to LT4 conversion package, I will need to upgrade to vented opti, correct? Just building ammo for the wife to spend 2Gs now and save the price of the opti down the road
Are any headers legal in CA?
Thanks for the help!
Sean
1994 Z28 - pretty much stock
Next:
Sean
