28 MPG on a new Impala SS
I dont get it. My 12 year old LT1 can do that and it runs on all 8 cylinders all the time. Why spend money on researching this, developing and implementing it for a seriously negligable improvement?
What is the point? What did they gain through all the effort? 1 or 2 mpg? Whoopie.
There are so many simple things the auto manufacturer can do to increase fuel economy. My dad's 2000 Lincoln Towncar is a prime example. It is the "L" Cartier with the factory limosine option and 6 inch stretch between the doors. It is a big, heavy fullsized car. His cumulative mileage currently reads 23.4. According to the car's computer, he gets between 30 and 32 on the highway depending on the grade and wind. He has seen it hit 33 on a long flat. The car sees mostly city driving.
He has done the following:
He keeps 35lbs in his tires
Duralube, Z-Max, and Teflon in the engine oil and the transmission and the rear differential and the power steering.
K&N filter
Magnets over the fuel lines (Fuel Saver)
Cut a hole in the airbox to open it up
Throttle body spacer between the TB and Intake Manifold. It has large cast aluminum fins in it and acts like the "tornado" only better.
Bosch platinum "double spark" plugs
If my dad can get 32 MPG from a 6 year old V8 land yacht with over 50,000 miles on it, what is the problem with the OEMs??? I really dont understand why cars are not getting better fuel economy from the factory.
K&N filter
his avg is 19 tho
You would think that some progress would have been made in the last 13 years.
better than my 94 3.4 5 speed with 3.42 gears. Go figure...................
