I've already looked through shbox.com's guide for this, and am familiar with the different adjustments. What I need to know is how the window should be set against the weatherstripping, how much tilt, how tight the felt stabilizers should be against the glass, etc. I don't want to break the door or glass. Regarding the felt stabilizers, should they be adjusted with the window AND door shut?
Readjusting door window?
Yes. Just push them against the glass lightly until they touch gently and then tighten them down.Originally posted by Jeffs Black 97 Formula A4Regarding the felt stabilizers, should they be adjusted with the window AND door shut?
Those two felt stabilizers are the last two things you adjust when re-adjusting a window. I usually remove(or loosen) them during adjustment and then reinstall them afterwards.Tracy
