buddy needs to do one on his 97 formula, i remember hearing that they are dry intakes, is this true? and egr tube, how does this come out(i assume it goes thru it) and any other tips?
LT1 Intake
LT1 intakes have no coolant passing through them. The tube for exhaust supply for the EGR merely unbolts from the back.
picRob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Dry intake means only air passes through it.Originally posted by 88bird5spdbuddy needs to do one on his 97 formula, i remember hearing that they are dry intakes, is this true? and egr tube, how does this come out(i assume it goes thru it) and any other tips?
Wet intake means air and fuel pass through it (carburetor, TBI, etc...)
So yes, it is a dry intake.
Use the shoebox to help you out with problems, pictures, etc... It's one of the best LT1 sites out there, if not the best.
I've never once had to take an EGR tube off of an LT1, but I can't imagine it being something a basic set of hand tools and a slight bit of knowledge can't take care of
It's "dry" in the sense that coolant does not pass through it like it does on a Gen 1 intake manifold.... that's what Shoebox was clarifying.
The EGR tube is connected with two studs.... remove the nuts and the tube should come off easilly. Look at Shoebox's "pic".Fred
